- AV-30 Count?
AV-30 Count?
is it possible to install in the Ercoupe, connectingpitot and static lines to it, since it is an experimental avionic?John Jones wrote: I'm going down a similar path but with a GRT Mini GA to remove the vacuum system and weight savings. For a couple of hundred dollars more it will have actual mag. heading vs. gps track, synthetic vision, a flight director the option to display a moving map or an actual HSI. It also has the capability to create a synthetic approach to any runway in its data base. It too fits in a 3 1/8" hole.
If so what would the process be like to install it?
- William James
Easy . . . push yourself away from the table quickly each meal for about 3 months !
- William James
A most incredible Instrument !! While it would not be legal , you could take nearly all the other instruments out of your bird and still have all you needed VFR . . . . . . Mine are set up for TAS , attitude , GPS tied to my 496 , DG , altitude set by barometer ,
Love my coupe but I wish I could get a better (shorter) take off performance . 7150 prop , strong engine (C-85) but can't get past 2200 RPM on take-off (LOOOONG take-off run ) Nearly always at max gross on takeoff . (2450 RPM full throttle at 5500 ft). My first bird was an Ercoupe in 1963 but I can't remember if it was the same performance . . . . for interest , I put wheel pants on my craft . Looks great , added 13 lbs to E.W. , but maybe 3 MPH to airspeed (if that)
I pray for a better 2021 for our fly-ins
