- Fuel leak (from carb?)
- Randy Branson
23 Nov 2022 09:07 #1
by Randy Branson
Replied by Randy Branson on topic Fuel leak (from carb?)
Thank you sir! I’m going to order one.
22 Nov 2022 23:48 #2
Replied by Ron Holmes on topic Fuel leak (from carb?)
- Randy Branson
22 Nov 2022 08:49 #3
by Randy Branson
Ron, The image of the "book" looks familiar. Where is it located? I'd like to get a copy.
Thanks!
--Randy
Thanks!
--Randy
- Mitch Muehlenfeld
31 Oct 2022 10:37 - 31 Oct 2022 11:26 #4
by Mitch Muehlenfeld
Replied by Mitch Muehlenfeld on topic Fuel leak (from carb?)
Here’s the answer from my IA. The neoprene tip was eaten away by auto gas. If you have the stc for auto gas make sure your carb has been overhauled for it. I have been using non-ethanol about 50 percent of the time. It will eat that tip. So my carb is going to be rebuilt to have the brass tip only so non-ethanol will be fine.
Last edit: 31 Oct 2022 11:26 by Mitch Muehlenfeld.
31 Oct 2022 01:05 #5
I had the exact same problem a couple of months ago... and new needle and seat in the carb and now zero leak... Mine was leaking at a pretty good clip... I have about 100 pictures but I won't show all of them...
The following user(s) said Thank You: Mitch Muehlenfeld
- George Polos
30 Oct 2022 22:11 #6
by George Polos
Replied by George Polos on topic Fuel leak (from carb?)
I have the same issue with my Stromberg carb. I even had it rebuilt. Still leaks. It will empty the header tank if you don't shut off the fuel valve. I always shut down by closing the fuel valve and allowing the engine to quit before turning off the mags. That way you won't forget. Of course it does not leak (certainly should not leak) while the engine is running, in case you were wondering.
Time to create page: 0.168 seconds
