- Fuel leak (from carb?)
- Mitch Muehlenfeld
30 Oct 2022 21:53 #7
by Mitch Muehlenfeld
Replied by Mitch Muehlenfeld on topic Fuel leak (from carb?)
I do have the stromberg, I have read that, but would it be leaking so much that a puddle would form in less than a minute. My tank would be empty in an hour or so for sure. It hasn’t been leaking at all until after this past flight.
30 Oct 2022 21:34 #8
Replied by Matt Gunsch on topic Fuel leak (from carb?)
you did not say what carb you have, but it is common on stromberg carbs. I just shut mine off with the fuel valve. there are a number of pages on the web about leaking strombergs.
- Mitch Muehlenfeld
30 Oct 2022 20:36 #9
Fuel leak (from carb?) was created by Mitch Muehlenfeld
I am 99 percent sure the leak I have is from the carb. I got back from a 2 hour night flight (nothing out of the ordinary The entire flight). Landed and was pushing the plane back and I noticed a pretty rapid drip of fuel coming from the bottom of the cowling. I opened the cowling up and fuel was leaking quickly from down the bottom of the carb. Probably would fill a 16 oz glass every minute. I turned the nose tank cut off and 15 seconds later the drip stopped. Nothing was wrong the entire flight. Any idea what my issue is?
Time to create page: 0.209 seconds
