- ercoupe performance
ercoupe performance
12 Nov 2017 21:11 #13
A licensed prop shop can cut it down and even change the pitch if you want
- Allen Deyoe
12 Nov 2017 20:31 #14
by Allen Deyoe
Replied by Allen Deyoe on topic ercoupe performance
Larry, can the prop be trimmed to a 70” by a prop shop and be OK with FAA Regs.
02 Oct 2017 13:17 #15
A 73" prop is legal only on the C-75. It is illegal to put that prop on a C-85. If you read the type certificate A-718 you will see that for the 85 horse engine the legal length for a McCauley prop is 69 ½ to 71 inches. The longer prop actually steals your horsepower - remember, hp comes from rpm, and a long prop is intended to spin more slowly with more torque.
- Allen Deyoe
30 Sep 2017 18:47 #16
by Allen Deyoe
Larry, it appears I have a McCauly CM7346 the standard prop for a 75hp. That means I have longer prop than your recommended size. I would think 46 would be a climb prop. What would you suggest I do?
- Tim Treat
29 Jan 2017 17:43 #17
by Tim Treat
Replied by Tim Treat on topic ercoupe performance
o-200 crank stc and a 48 pitch is a rocket ship
- 9987
25 Jan 2017 19:37 #18
by 9987
Replied by 9987 on topic ercoupe performance
Ken, Sorry for leaving you hanging. I'm definitely satisfied with the improved performance in the climb,lost about 3to4 mph in cruise but that's ok with me. I don't have actual numbers in my head but will pay more attention the next time I fly. Right now a small wiring issue has turned into close to a complete panel rewiring job so I'm down for awhile.
Time to create page: 0.125 seconds
