- Fuselage tank overflow elbow missing...
06 Oct 2024 23:33 - 06 Oct 2024 23:35 #1
Replied by Brooks McNew on topic Fuselage tank overflow elbow missing...
Just as a reference, here's what my fuel indicator looks like when the fuselage tank is "full" i.e. fuel is flowing out through the overflow pipe, sitting level on the ground.
I have an almost new plastic float and this is as high as it gets, unless you're in the air and put the nose up!
I put that little black strip of tape on the glass tube as a reference to the"full" level. Incidentally, there's still almost 2.5 gallons remaining in the fuselage tank when the float gauge bottoms out.
Last edit: 06 Oct 2024 23:35 by Brooks McNew.
06 Oct 2024 18:37 #2
That's EXACTLY what mine looks like... the fuel pumping around was just obscuring it.
06 Oct 2024 18:21 #3
Replied by Matt Gunsch on topic Fuselage tank overflow elbow missing...
06 Oct 2024 17:40 - 06 Oct 2024 17:41 #4
This is a 415C but it's a 6 gallon tank. My "in" from the pump and overflow "out" are both 90-degree fittings that enter the tank through the rear wall.
The "out" to the gascolator is a straight fitting on the bottom of the tank.
Last edit: 06 Oct 2024 17:41 by Brooks McNew.
- James Davis
06 Oct 2024 10:53 #5
by James Davis
Cool video but I don't think it's the 415C's 5 gal tank model because it seems that the flow going upwards like a fountain. is that coming from underneath or is it the angle of the video?
Replied by James Davis on topic Fuselage tank overflow elbow missing...
Not sure if this will help, but here's a very short borescope video of my fuselage tank, taken when I was testing the new electric fuel pump.
You can see the input and overflow elbow.
05 Oct 2024 23:45 #6
I posted photos of both, the Alon tank is the welded tank
