- Need New ELT - Suggestions?
09 Dec 2024 11:07 #1
Replied by Matt Gunsch on topic Need New ELT - Suggestions?
make sure you read the ICA instructions, some of the 406 ELTs require them to be send to a qualified shop for their yearly inspections. or to a shop that has specialized testing equipment.
- Tim Cowden
03 Dec 2024 13:08 #2
by Tim Cowden
Replied by Tim Cowden on topic Need New ELT - Suggestions?
Thanks John and Super User. I'm going to buy the ARTEX 345 and will connect it to my Aera 760 to get the 100 meter accuracy. I ordered it with the Baud 4800 to be compatible with the portable 760. The ARTEX battery lasts 6 years, something I like.
Tim
Tim
02 Dec 2024 15:31 #3
Replied by John Jones on topic Need New ELT - Suggestions?
This is from the ACK E-04 installation instructions:
SECTION 6 GPS INTERFACE INSTALLATION
The model E-04 ELT will interface and recognize EIA standard RS 232 data at 1200, 2400, 4800, and 9600 baud from NMEA 0183 sources, Garmin panel mount, and handheld GPS’s along with Bendix/King GPS’s. See section 18 for GPS data formats, and connection information, along with other manufacturers GPS’s known to be compatible.
- Super User
02 Dec 2024 12:21 #4
by Super User
Replied by Super User on topic Need New ELT - Suggestions?
Be sure to read the installation instructions carefully - I wonder if the requirement for GPS input is based on a certificated GPS unit that's installed in the plane permanently (i.e. a permanent part of the plane).
02 Dec 2024 12:17 #5
Tim- I have an Aera660 RS-232 output sent to my ACK-E-04 ELT. The advantage of using the Aera's gps signal is it gives a more precise location over the "generic" location provided by the ELT itself.
Depending on which ELT you're replacing, ACK may have a conversion option that would ease the installation. The Artex Keith mentioned may do the same, and also have the same "precise" gps capabilities.
John
John
- Tim Cowden
01 Dec 2024 13:04 #6
by Tim Cowden
Keith,
Thanks for this excellent discussion. I do have GPS (Garmin Aera 760 - mounted in the panel) and ADSB-in with a Garmin GDL-50. I believe I'll buy a 406 Unit.
Tim
Tim
