Problem/Window Replacement
  • 10109
26 Jan 2016 13:32 #1 by 10109
Replied by 10109 on topic Problem/Window Replacement
Lynn, Thanks for the info. We did just as you said and it was perfect. Regards, Larry
26 Jan 2016 07:36 #2 by Lynn Nelsen AP/IA
Replied by Lynn Nelsen AP/IA on topic Problem/Window Replacement
Hey Larry: If you have the bubble windshield, the strap over the top of the windshield must be removed to replace the windows. If there is no cut out in the rear, there should be one in the front under the windshield hold down strap.
Lynn
  • 10109
08 Dec 2015 17:00 #3 by 10109
Problem/Window Replacement was created by 10109
Every 415C I have ever seen has a plate you remove to replace the pull-up side windows. It is usually mounted on the top rear crossover that holds the rear part of the window. You remove two screws and that allows you to slide the complete window out for replacement. For some reason mine 415C does not have it. I know we can take a dremel and cut one out. But, does anyone know of another way to reduce the windows?
Regards, Larry McCartin N93436 Ercoupe
