- New Avionics - How the project evolved...
19 May 2025 20:46 #1
Replied by Larry Snyder on topic New Avionics - How the project evolved...
Some members have gone to great lengths to get the FAA's blessing for non-TSO'd in our Ercoupes, which were sold new with non-TSO'd instruments (there was no such thing as TSO). I believe the only things you put in a coupe that must be TSO'd are the transponder, encode, ADS-B and GPS source (if not built into the ADS-B transmitter). When I replaced my altimeter I did not get a TSO'd one. Or airspeed indicator, either. But I am using a KT-76A transponder and uAvionix tailBeaco, both of which are TSO'd.
17 Mar 2025 19:28 #2
Replied by Brooks McNew on topic New Avionics - How the project evolved...
Absolutely agree with everyone about non-TSO instruments & avionics being okay from a regulatory standpoint.
in my situation I'm working with a A&P/IA who charges me about a quarter of what he should, and as he's gotten comfortable with my style he gives me pretty wide latitude to do work that he's taught me, and then he inspects and signs off on it with extremely minimal expense. Sometimes it's worth making him happy by paying a little more for the TSO version - he's the one who's signing his name to it.
17 Mar 2025 16:16 #3
Replied by Ronald Raty on topic New Avionics - How the project evolved...
I think that using TSO instruments is probably a good idea from a safety point of view. However, I also think it has been pretty well settled (by AOPA pushing the issue) that an airplane certified without TSO instruments does not have to have TSO instruments, from a regulatory point of view. I usually buy the cheaper non-TSO version if an identical TSO version is also available. I'm assuming the manufacturers don't go to the expense of running two assembly lines, one being higher quality than the other. Identical instruments come off the same line and are of equal quality. The additional TSO cost is to cover liability and record keeping.
17 Mar 2025 10:48 #4
Replied by Matt Gunsch on topic New Avionics - How the project evolved...
the AV-30 cannot replace your airspeed indicator, and most coupes did not come from the factory with an attitude indicator (I know they were in Alons and Mooneys), so replacing it with an AV-30 is not a big deal, and I installed the experimental version and have the AV-link as well.
- Eric Ingram
24 Feb 2025 15:27 #5
by Eric Ingram
Replied by Eric Ingram on topic New Avionics - How the project evolved...
Given the situation, it makes sense. I think (had you needed the AV-30) the argument could have been made in support of using it. In the future, it might be worth considering for other optional things.
24 Feb 2025 15:03 #6
I think (and don't quote me on this) that it's a grey area as far as using non-TSO instruments in an aircraft this old. My A&P wasn't comfortable with this one and he's been *fantastic* to work with so I didn't want to push it.
His interpretation is this: take the ammeter for example. The original ammeter was not a TSO instrument (which didn't exist in 1946!) so when I needed to replace it he was fine with a non-TSO ammeter as long as it was just like the original, i.e. the one sold by Univair who holds the type certificate. But if I wanted a completely different type of ammeter, he would want it to be a TSO unit.
Another deciding factor was that I purchased my Coupe from the widow of the previous owner and she was trying to sell the coupe and also her husband's semi-finished RV8 which had been left with all its avionics in an unfinished heap. It needed the AV30 more than I did.
