- Control Wheel’s on Erco 415-D possible?
24 May 2024 22:20 - 24 May 2024 22:28 #1
Replied by Warren Hampton on topic Control Wheel’s on Erco 415-D possible?
Yes unless shafts were cut. Some yokes are deeper so they would cut the shafts. Yokes are usually bolted on so you may have to large holes you may need new shafts also.
Last edit: 24 May 2024 22:28 by Warren Hampton. Reason: spacing
23 May 2024 15:49 #2
Replied by Brooks McNew on topic Control Wheel’s on Erco 415-D possible?
I believe you will need the wheels and also control shafts that are a different length, but the real resource for this is
Precision Services Inc.
803-360-2061 no calls after 10PM Eastern
- Torsten Roeder
19 May 2024 13:37 #3
by Torsten Roeder
Control Wheel’s on Erco 415-D possible? was created by Torsten Roeder
Good day everybody,
I recently owned a 1947 Erco 415-D.
Serial Number is 4737.
Is it possible to exchange the two Yooke's for two steering wheels?
(The "DELUXE CONTROL WHEEL" from Univair only goes up to SN 4423)
Thank you for your answers!
Best regards
Torsten
Best regards
Torsten
