- Removing Rudder Pedals & correct Rudder Rigging
29 Nov 2025 17:45 - 29 Nov 2025 17:50 #1
Replied by Mac McCormick on topic Removing Rudder Pedals & correct Rudder Rigging
Thanks Matt & Ron! I found SB59 no drawings though. From your description in your reply and the photos I found it looks like a very straight forward job. Remove extensions, remount the clevis to the original cables still there, and boom. Done. I'm a bit of a visual learner. Takes me a moment to understand.
Manual B&W image
With Rudder Pedals
Without Rudder Pedals
Manual B&W image
With Rudder Pedals
Last edit: 29 Nov 2025 17:50 by Mac McCormick.
19 Jun 2025 12:08 #2
Replied by Matt Gunsch on topic Removing Rudder Pedals & correct Rudder Rigging
There is a service bulletin that covers rigging, the control surface travels are listed in the Type Certificate, the rudders move more outboard than they do in board.
17 Jun 2025 20:56 #3
Replied by Ronald Raty on topic Removing Rudder Pedals & correct Rudder Rigging
When I removed my pedals, the original rudder cable was still there, and extended to the rudder pedals with a turnbuckle connection. I just unscrewed the extension cable, screwed a clevis into the turn buckle, and attached it to the "mixer". The rudder cables cross inside the fuselage so that when you bank to the right, the rudder also turns to the right so the turn is coordinated. I spent a lot more time checking rigging and adjusting cable tension than I did actually removing the rudder pedal assembly.
17 Jun 2025 15:33 #4
Removing Rudder Pedals & correct Rudder Rigging was created by Mac McCormick
Been scouring the forum and the wild wild web so Can get my mechanic a leg up on removing the rudder kit. I have a PDF of a 1959 service manual and am not seeing a rigging guide. Is there a guide out there? Also when the yoke is turned, say to the right, which directions should the rudders turn? Can I assume if I bank right it inputs right rudder? And how much do they deflect/move?
