Matco M. Cyl Brake Pressure Hose
  • Dennis Tar
31 Jan 2021 15:21 #1 by Dennis Tar
Matco M. Cyl Brake Pressure Hose was created by Dennis Tar
I have the Matco master cylinder that replaced the original Scott. I need to replace the pressure hose that needs to be 6 inches in length to meet the hard metal line.
Vern / Skyport apparently only has the original 8 inch hose that mated to the original Scott master cylinder. ( Univair only sells the hose by the inch to make your own)
Has anyone found a 6 inch hose with the right connectors or does it need to be custom made?
Thanks for any advice
