Right turn at altitude, straight and level flight - Ercoupe 415-D
  • Ken Thompson
10 Nov 2019 11:36 #7 by Ken Thompson
Todd. Check your FB Messenger for pics. I couldn’t upload pictures here.
If you don’t see it, Look under “other” or “filtered” messages.
  • Todd Halver
05 Nov 2019 06:34 #8 by Todd Halver
Thanks for the input Edward.
05 Nov 2019 00:13 #9 by Edward Moore
PS: Credited to Henry for bringing it up - he "stimulated" me to respond with my experience.
05 Nov 2019 00:08 #10 by Edward Moore
Follow the procedure as outlined. I had a heavy left wing and went to "opposite wing", e.g. right aileron, and using vice gripe pliers with tape on jaws to protect metal and appropriately adjusted jaw opening to not "crush" the skin and making just a small amount of pressure in between alternate rivets along the entire length of the aileron flat trailing edge solved my problem. Approach cautiously and don't be heavy handed - may take more than one procedure/flight check to get what you want. You will note that the trailing edge can be moved with moderate pressure but it does have a "spring back " effect. Keeps your Coupe looking "standard"!
  • Ken Thompson
04 Nov 2019 17:14 #11 by Ken Thompson
Todd, I'll try to remember next time I'm at the hangar. Probably this weekend.
  • Todd Halver
04 Nov 2019 16:57 #12 by Todd Halver
Ken - can you send me a pic of your tabs? Curious on size, location etc. Thanks,.
Time to create page: 0.101 seconds
