- Oil Drip from Air-box Drain - Normal?
- Ken Thompson
25 Nov 2021 07:09 #1
by Ken Thompson
Replied by Ken Thompson on topic Oil Drip from Air-box Drain - Normal?
Tell us more about that “long pull cable.” I’ve never heard of it. What does it do?
I think most of us get around 5gph without a special cable.
- William James
25 Nov 2021 06:57 #2
by William James
Replied by William James on topic Oil Drip from Air-box Drain - Normal?
The Strom set-up in our birds do not allow for mixture cut-off . Only mag shut down. I had a "long pull" mixture cable installed on my C-85 and now can lean down to 5 gal/hr (or less) Before the cable it burned 6 to 7 gal/hr
- Ken Thompson
24 Nov 2021 14:35 #3
by Ken Thompson
I just shut off the header tank valve on my ramp and rev it up until it dies of starvation. I do this every time before I hangar it.
03 Sep 2021 20:48 #4
Replied by Ronald Raty on topic Oil Drip from Air-box Drain - Normal?
Oh, yeah. Right. I turn off the fuel valve a couple minutes before getting to the hangar.
- Brady Buttterfield
02 Sep 2021 20:58 #5
by Brady Buttterfield
Replied by Brady Buttterfield on topic Oil Drip from Air-box Drain - Normal?
Okay great. Now how do you lean out a Stromberg enough to kill the engine? Pulling the mixture doesn't seem to kill it.
02 Sep 2021 19:12 #6
I had the same problem. The A&P in the hangar next door told me that as the engine quits, there is considerable vacuum in the intake manifold which sucks oil past the valve guides. The solution was to shut off the fuel, and as the engine dies, open the throttle wide open so lots of air gets into the manifold. The drips have stopped.
