- fuel tank caps
fuel tank caps
- 9987
06 Jul 2016 18:47 #1
by 9987
Replied by 9987 on topic fuel tank caps
Thanks, I just bought new gaskets and will put them on at next flying session.
- Tim Treat
05 Jul 2016 20:39 #2
by Tim Treat
Replied by Tim Treat on topic fuel tank caps
+1
also make sure that the gaskets seal tightly
30 Jun 2016 13:25 #3
Replied by Larry Snyder on topic fuel tank caps
The hole points forward, slightly pressurizing the tank. If it's on backwards, fuel will be siphoned out as you fly. Tell your genius line guy that unless he is flying the plane, do what he's told!
- 9987
30 Jun 2016 13:01 #4
by 9987
fuel tank caps was created by 9987
I need help settling a local problem. When I purchased my Ercoupe I was told that the fuel caps need to be replaced so that the small hole in the cap points to the front. It seems that the line people who fuel my plane insist that the small hole should point to the back, the top part of the cap is higher where the hole is and I think this is influencing their thinking. Some claim to have been doing this for some time. Someone please explain to me the proper way the caps should be replaced and why so I can pass it along. Thank you
