Ailerons Pre-flight
  • 8419
10 Aug 2016 12:28 #1 by 8419
Replied by 8419 on topic Ailerons Pre-flight
I do the S turns as I taxi out and check aileron deflection.
10 Aug 2016 11:58 #2 by James Good
Replied by James Good on topic Ailerons Pre-flight
Good question. I just give the ailerons a wiggle after run-up, but that's not testing for full travel.
  • silverwing
09 Aug 2016 14:16 #3 by silverwing
Ailerons Pre-flight was created by silverwing
Hi All,
When checking that controls are free and correct as is normal for all airplanes,
what is the best method for the Ercoupe? Mine has rudder pedals, but the yoke it still connected to the nosewheel, so the way I check the ailerons is to do 'S' turns while I taxi.
Does anyone else do it differently or have another method?
Thanks
