G-HARY
28 Jun 2024 00:16 - 28 Jun 2024 00:27 #7 by Warren Hampton
Replied by Warren Hampton on topic G-HARY
Is that not the one that the  Alon Don Abbot has now down at Page Field in Ft Myers Fla. it is something like that. All Alon A-2s had C90-16F with V pumps This Alon came out of Canida. But as Matt thy too run V syst. Then some of the early A2s may have come with the C90-12F
Last edit: 28 Jun 2024 00:27 by Warren Hampton.
27 Jun 2024 18:19 #8 by Larry Snyder
Replied by Larry Snyder on topic G-HARY
G-HARY is an Alon and I think anll Alons were equipped with a vacuum pump. So why any venturis? Best to follow the vacuum tubing and see what your vacuum instruments are running off of.
27 Jun 2024 18:11 #9 by Matt Gunsch
Replied by Matt Gunsch on topic G-HARY
I've noticed that this airplane has two venturis installed. Since it has a vacuum system, anyone have knowledge on why he has the venturis?
Ed
And where do you think the vacuum to run the instruments comes from? it is from the Venturis.  There are only a few sources of vacuum to run instruments, Venturis, or a wet or dry engine driven vacuum pump.
  • Edward Woerle
24 Jun 2024 10:29 #10 by Edward Woerle
G-HARY was created by Edward Woerle
Ed
