- Broken exhaust caused by worn lower engine mounts
- Keith Whitcomb
13 Feb 2025 07:12 #13
by Keith Whitcomb
Replied by Keith Whitcomb on topic Broken exhaust caused by worn lower engine mounts
Vernon Gregory @ skyport suggested may have bent the engine mount
12 Feb 2025 14:50 #14
Replied by Ronald Raty on topic Broken exhaust caused by worn lower engine mounts
Aren't the mounts on an Alon different than the 415CDE?
- Keith Whitcomb
11 Feb 2025 23:01 #15
by Keith Whitcomb
Broken exhaust caused by worn lower engine mounts was created by Keith Whitcomb
I recently had my exhaust nearly fall off. After I had it welded up and I could not align the exhaust flanges flush with the exhaust port. The exhaust pipe hitting the fuselage wouldn’t let the two surfaces meet.
My welder suggested I look real hard at the engine mount and the motor mount. Sure enough the lower motor mounts weren’t as symmetrical as the upper ones, and there was a small gap that I could stuff part of a zip-tie in a little way.
Now it looks like I will be replacing all 4 motor mounts very soon. Any advice by anyone here who has been down this rabbit hole?
