- Broken exhaust caused by worn lower engine mounts
- Randy Phillips
14 Mar 2025 07:19 #7
by Randy Phillips
Replied by Randy Phillips on topic Broken exhaust caused by worn lower engine mounts
That's exactly what mine looked like as well. Bottom ones had worn almost all the way through.
- Keith Whitcomb
12 Mar 2025 23:58 #8
by Keith Whitcomb
Replied by Keith Whitcomb on topic Broken exhaust caused by worn lower engine mounts
08 Mar 2025 22:33 #9
Replied by Warren Hampton on topic Broken exhaust caused by worn lower engine mounts
Mooney 590029 came with 135 HP Lycoming It was down in Texas the last I knew.
08 Mar 2025 22:28 #10
Do you have the rubber hangers on the bottom tail pipes ? there to sole the vibs
- Keith Whitcomb
06 Mar 2025 23:25 #11
by Keith Whitcomb
I spent the day replacing the rubber motor mounts today. Oh what fun! (Not!)
Vernon Gregory @ skyport sent replacement parts. Nobody mentioned that the top and bottom bolts have different lengths.
By pure luck, I got one side right.
I get to redo the other side tomorrow.
13 Feb 2025 09:34 #12
Replied by John Jones on topic Broken exhaust caused by worn lower engine mounts
The same part number shows for all models except Mooneys: 590029
